Problem flashing BIOS!
Zer0Cool
I download the latest BIOS for my new mobo "DFI LP UT P35" I ran the file and the files were uploaded to to my floppy disk.
When I power the sysyem I press Esc to boot to the "boot mode" I then select "boot from floppy" The Flash bios screen then apears. There is a msg "Rename the file" or something like that, the file name is alredy there and I dont have to rename anything. The problem is when I press Enter nothing is happening...When I backspace to rename the file nothing works... (I'm NOT using usb keyboard) I tryed pressing all the buttons! (when i do alt ctrl del the sysyem restarts)
What do I press? Someone plz help
This are the files I have on my floppy;
AWDFLASH.EXE
LP35D317.BIN (the icon on this file is from my VLC player...dont know if it means anything)
Thanks
EDIT
I just tried creating a "autoexec.bat" file with the fallowing code iside "awdflash /py/sn/cd/cp LP35D317.BIN" and when I drag the .bat file to the floppy, it sas the file with this name alredy exists...but I cant see it, and I have my hidden files enabled...
Well. I don't have any advice on this but just thought i'd tell you to be careful.
I just fucked up my Asus m2n-sli deluxe today. Hopefuly Asus will take mercy on me and RMA it. In my defense, I just bought their $1250 laptop :)
But basically what happened to me was I went to update the BIOS and then it said it was fine and it would reboot, when it rebooted I didn't even get to the bios.
Good side of it is it finally gives me a reason to upgrade.
