Hi everyone,
My hands for 'some' reason jerked while i was soldering the wire next to that resistor, so i chipped it off, i then removed all the soldering i made, started up the computer, but the card didn't display any picture on the screen, however, it booted into windows, cause i could hear the harddisk working, then the loggin windows sound.
I then got a replacement resistor (based on an advice from a friend), and it worked again no problem.
Then, i was measuring the voltage of the core to make sure everything is ok, it measured 1.2v, i increased it a bit by bit to get the max for my cooling, i reached 1.53v, got 930 on the core, stable and everything again was excellent and fine.
Decided to wrap it up, and close the case, but decided to measure the voltage one last time just to be sure, worst mistake of my life ... shorted the +ve and -ve lead from the PCI-e plug to card by accident (out of excitement, or maybe i have some nerves problem ), it made a spark, then no picture, just like before.
It could boot into windows still, same previous problem, so i simply tried increasing of decreasing the resistance (from its default of 1.2v, i returned everything to default just in case), not budging, boots into windows but no picture from the computer startup.
Oh, one more thing to note, before i fixed the first problem, and also during this last problem, in both cases the voltage reading of the core was zero.
I know i screwed up BAD, because i'm careless when i get excited , and i know i burnt something, so, my question is ... can this be fixed, or is this the 'real' end of it.
I'm going to get a 8800GT next week anyway, but would like to get this card working still, it would be a waste not to , especially that i learnt a LOT of lessons in modding, and in electronics from tampering with it, and above all, in carefullness .
I would really appreciate any help, thanks a lot guys .
