Prime 95 questions
NukeULater
Okay, I'm in the middle of OC'ing my Q6700. But I noticed when I run prime 95, it doesn't run all 4 cores at 100% load. Is that normal?
If you need more info just ask.
There is another version of P95 that will run on multi-cores.. or you could just run multiple instances of the one you have.
How do I do that? I've tried opening prime 95 twice and it just selects the one I already have open.
