Prime 95 not loading CPU, help!
HybridHB
Ok guys i wanted to stress my cpu but it seems prime95 isnt doing that to my rig.
Is something wrong? I used the torture test overnight and not once did it take my cpu to 100% like it used to on my other rigs.
K8N NEO2 Platinum (bios 1.3)
A64 3200 90nm (10x240)
2x512 Mushkin LVL I (slots 1 and 2)
In the command prompt, go to where you installed Prime95 and type prime95.exe -an
That will open up another prime95 session that you can run at the same time, I personally dont even bother with prime unless I run them both for at least 12hours stable.
Sejin
Thanks for the info, but i am still boggled as to why it doesnt load the cpu like it used to? As you can see it didnt even finish test 1 in 9 hours. My previous Athlon XP rigs would go though all the tests in a couple hours. Does this happen to anyone else?
Nevermind, i switched from blend to High FFT and got 100% load the whole time. Thanks for the help guys.
