This will depend on a few things, mostly the motherboard- visit your manufacturer's webpage and determine if it is compatable.
The VRM's tend to make the biggest difference- if your board supports Williamette core processors (PIV's below 2.0 and not an "A" rev and Celery's below 2.0), then it will NOT support Prescott (but will Northwood). If it only supports Northwood only, it will probably support Prescott too... just check out your mfr's page.
The motherboard needs to have support for 800MHz FSB CPU's, it must have VRM specifications that match Prescott requirements. It must also have a BIOS that supports it.
On my Asus P4C800 Deluxe, I had to update my BIOS using a Northwood on my board. With the Prescott installed the system wouldn't boot at all.
