Jun 7, 2004 #1 B Bigga Weaksauce Joined Feb 21, 2002 Messages 102 Post youre overclock settings for your prescott cpu
Jun 7, 2004 #2 A A-Speck n00b Joined Jun 7, 2004 Messages 2 System: Prescott 2.8 ES @ 3.5 (250 FSB x14 & 1.425 V) PMI PC3200 (5:4) Abit IC7-MAX3 Ambient varies from 60 F to 90 F in the computer room, so temps are iffy Anywhere from 42 idle and 46 load to 46 idle and 51 load. In the morning it's stable at 1.375, but as the room heats up I need a little more voltage to run through Prime95. Cooling: AMS G-Tower Swiftech MCP600 Dtek Whitewater (Al top) Black Ice Xtreme (mounted at rear inlet) Swiftech MCW50 Two 120mm Evercool Aluminum Fans (rear inlet, blowhole exhaust) Enermax Fan Controller
Jun 8, 2004 #3 C codeflux 2[H]4U Joined Mar 28, 2002 Messages 2,530 had 3.0E @ 3.6 @ 1.475v - was getting way too hot, so i traded it for 3.0C -> hits 3.75 @ 1.7v & runs much cooler.
