AznAnarchy99
- Jan 18, 2005
my room temp jumps 10 degrees when my comp runs.. with the window open and door open... and i litterally sweat when i game...
Are you using the stock HSF on that Prescott? Are you concerned that those temps are shortening the life of the CPU?SirKenin said:Just think, that used to be the Axp claim to fame exclusively. I have three Intels running in my office, one of them being a Prescott. It gets very warm in here thanks largely to the Prescott, although having three computers running 24/7 does not help matters any. I am going to have to bring my portable room air conditioner in here soon to keep it cool.
Someone should test and measure this..Demon_of_The_Fall said:yeah, a CRT should put out quite a bit more heat than a prescott.
Dillusion said:Ive had pretty much every processor out from every refresh for the last four years, and whether it was an AMD, INTEL, EPIA...silent cooling, aircraft carrier style cooling, water cooling, or whatever else.....my room would ALWAYS get hot. Its just the heat in general building up. IF you have your computer inside a desk or under a desk thats closed on all sides, or a desk with one of those tower cut-outs, it becomes a big oven.
When I grow up I want to be just like you.cell_491 said:my old pressy used to heat up my room too thats why i switched to A64
SirKenin said:When I grow up I want to be just like you.
sabrewolf732 said:uhh, my comp doesnt warm my room at allMost comps use around 300 wats (single cpu, mobo, 2 sticks of ram, vid card, single drive). thats like 5 light bulbs, and not all of that energy is put off as heat (im betting less than half is), so how can it warm a room :?
chrisf6969 said:Try sitting underneath 5 lightbulbs shining on you. It gets hot.
If your room is hot, you have poor circulation in your room and/or house. Try using a ceiling fan to circulate the air. Then your central AC should be able to remove the heat from the room more efficiently than if all the heat is in one corner next to you.
My PC is right next to the air intake (and thermostat) for the Cental air unit for the whole house, so the heat gets sucked away very efficiently and doesn't ever bother me.
Oh, you have an A64 too, which explains you rising to the defence against a silly joke. Can I be just like you too? Why are you even in an Intel forum anyways? Isn't the nursery down the hall and on the right?fuelvolts said:Ohh...big man!
He was just giving a suggestion, grow up already.
WOW...im sorry but i didnt mean my comment to be such a big deal with people, I was just saying that its perfectly normal for a prescott to heat up a small to medium sized room because guess what ive had TWO prescotts a 2.8E then a 3.4E and let me say that both got pretty damn hot...hot enough to make my entire room feel like I was sitting in Satans waiting roomSunborder said:Kenin, chill out (pun intended).
I have both A64 and P4 systems. Each suits a purpose. The P4E is for business and multitasking, the A64 is my fileserver and game machine.
The P4 overheats like a 67 chevy with a leaky radiator in the Mohave in July. The A64 doesn't handle the multi-tasking as well. So what?
!!!!!!s will be !!!!!!s, but still no need to act like children.
I'll chill out once I wheel my a/c in here and turn it onSunborder said:Kenin, chill out (pun intended).
...not only "asking for trouble" (...trolling?), but against the rules:However, flaming for a joke was just asking for trouble.. I couldn't resist.
You can argue, disagree, berate, etc. all you want but when it gets personal, count on a mod or admin to step in and make required changes. If it continues, an Admin may step in and make more permanant changes....and some of you may not be thrilled with the outcome. Fair warning - B.B.S.(1) Absolutely NO FLAMING OR NAME CALLING. Mutual respect and civilized conversation is the required norm.
