Preparing for a PSX case mod
Hyperious
I'd like some advice on setting up a system using the my old PSX case. One of the problems I foresee is that I very much doubt I could fit a power source inside the case, let alone find a motherboard that is small enough (unless it's one of those shuttle ones?). I'm also probably going to need to trim the inside of the case a bit, too... neat as it would be to use the original cd reading bay that's a decent chunk of space being wasted. Is there such a thing as ordering a custom motherboard (more than likely a dumb question, as I have serious doubts about that)?
The dimensions I'm working with are
H 2.3622 in.
W 10.6299 in.
D 7.40156 in.
Not a whole lot of room to work with, there. I've been looking around and haven't had a whole lot of luck finding motherboards quite THAT small, although I've come damn close with some of the Micro ATX motherboards.
Perhaps look into the motherboards and power supplies used in ultraportable laptops.
