ppd issue
crashbox
so i feel like there is an error with my ppd, i have been folding for 2weeks straight using an older dual processor xeon server, it has 2 xeon 3.2ghz with HT, its an older socket 604 server but i have been using my AMD 1100T thats oc'd to 4ghz and usually complete 2 to 3 wu's while at work plus a gtx 470 using the gpu v3 client that completes a few more wu's by its self.When i get home form work i turn off folding on that machine due to needing the resources for rendering some videos using AE. My video card alone should have me over 4k ppd by its self let alone the old xeon server and the 6 core amd processor, I have made sure that all my clients are using the same pass key, username and team 33, anyone have any idea as to whats going on?
What's your user ID/# ?
What arguments are using for each client?
What guide did you use to set up your boxes?
User ID is crashbox
on the cpu client im using -smp
no arguments for the gpu client
Well i first used the gpu tracker v2 client, after i was told that it was horrible for smp a guy linked the v6 smp console client setup, so i followed it to the letter, and i setup the gpu v3 client my self
Looks like you're just now getting the bonus points for SMP units. You have to finish 10 smp units before getting it. You should be getting a boost from now on.
Your points are here. I would double-check your GPU configuration. The GPU should generate points every stat update when it's running and complete multiple WUs a day. Your completed WU count is pretty low, so it looks like SMP only.
You will have to check back in a couple of days to see if your points are stabilized. As of today you made 7,400 points so I think you are starting to get the points you should be.
