unwantedSN
- Jan 9, 2009
I wasnt sure where to put this but I know a lot of you here use power shell. Im having issues trying to wrap my head around the correct syntax and thought maybe some of you could help. In a nutshell im trying to copy a file from one path to another, but its a bit weird. What i need to happen is to copy from my source to multiple destinations. I need to go from c:\newfolder\file.ext to d:\employeefolders\unkown_variable\newfolder\filename.ext
The\unknown_variable\ folder is consistently changing the only thing that i need it to do is put my test\file.ext directory in there if their is a folder.
here is what i tried, but it fails.
PS C:\> Copy-Item C:\test\testfile.txt d:\employeefolders\*\test\
anyone know how to make this work?
