PowerMac G5 Project - Not like the others ! - Warning Loads of pics !
MrAhlefeld
Old build log not posted on [H]ardOPC, updated since with new hardware
This build was originally made in 2012, but updated a few months ago.
Time for a (old) project
I've allways loved the style of the PowerMac G5 enclosure, and with much inspiration from other people's builds I've decided to do my own.
This will not be like the other G5 ATX convertions with Lian-Li motherboard tray
(sorry guys, I think those builds look cool but it's not my style)
I've sourced a PowerMac G5 from a local MAC shop in my city. It was dirt cheap, cause one of the handles on the to was bend out of shape.
Watercooling: I will be using some of my old parts as I love my Eheim 1048 pump, just can't beat it at those noise levels.
SPONSORS - None
List of parts:
Will be updated as the build comes along.
OLD SPECS
System
PSU - CHILL INNOVATION CP-1000M 1000W Modular PSU
MB - ASUS MAXIMUS V FORMULA
CPU - Intel Core i7-3770K
RAM - Kingston HyperX Predator 2400MHz 4x4GB - Ugly blue color, but this will be solved once I know the RAM is 100% ok
GPU - NVIDIA GTX580
SSD - OCZ VERTEX 3 120GB
HDD - 1.5TB SATA-II HDD 3.5"
HP SAS/SATA 2.5" 8 Bay Enclosure
Cooling
CPU - EK Supremacy Acetal
GPU - EK GTX580 Acetal
RAD - EK XT 360
RES - EK - Multioption RES X2 Advanced
PUMP - EHEIM 1048
FAN - ARCTIC F12 x 3
FITTINGS - Mixed bunch of EK's
TIM - Coollaboratory Liquid Ultra
UPDATED SPECS! 2014
System
GPU - NVIDIA GTX580
GPU - NVIDIA GTX580
Cooling
RAD - EK XT 360
RAD - EK RX? 360
PUMP - EHEIM 1048
FAN - ARCTIC F12 x 6
UPDATED SPECS! 2017
System
PSU - Corsair RM1000
CPU - Intel Core i7-3770K @ 4.7Ghz
RAM - 32GB Cricual Ballistix 1600Mhz @ 2000Mhz
GPU - NVIDIA GTX1080 Ti iChill X3 Ultra - something.. it's an OC'd FE board with DVI Connector
SSD - A bunch of different :) Look at the SATA cage for sizes
HDD - 2TB
Cooling
GPU - kryographics Pascal NVIDIA TITAN X and GTX 1080 Ti acrylic glass edition, Nickel plated
GPU - Backplate for kryographics Pascal NVIDIA TITAN X and GTX 1080 Ti, aktiv XCS
RAD - EK XT 360
RAD - EK RX? 360
PUMP - Dangerden D5 Vario
FAN - Corsair ML120 Pro Premium
FITTINGS - Mixed bunch of EK's and others
No updates for the 2017 Rebuild yet ! need to edit and upload pics first
Hope you enjoy reading / watching the progress
All comments are wellcome !
Pictures !
The PowerMac G5
Damage to back handle - Bump on top and squished out of shape
Ouch
More damage showing
Inside shots before stripping
Backside
An old HP server donated it's backplate to be modded (how nice of it) :LOL:
"this will be mounted on the inside"
Front
Random shots
Random shots
Backplate mounted with magnets from old 3.5" HDD's. (will be glued once the final MB is mounted and everything is fitted / sanded / painted) :thumbup:
Original MB standoffs mounted to defective MB (allmost donated by local HW supplyer) was 7AUD approx.
The MB curves slightly and a few of the standoffs lift off the surface :mad:
MB standoffs cleaned off, ready for epoxy :thumbup:
Epoxy Steel from hobbyking.com with 4 min. setting time (must work fast) :p
MB placement making sure PCI-E cards fit. The big iron blocks hold down the MB so it dosen't curve.
The Alu pipe is venting the epoxy fumes out of the room.
Random shot
4 Minutes later
More Epoxy added on top for safety (not really needed but hey) ;)
That's it for now I think, more to come :cool:
Time for a small update... :)
HP SAS / SATA Drive Cage (Can't take credit for this idea, original by MrBeanPhillip) But mine will be mounted differently :D
No SAS drives will be used - they get too damn hot, are noisy and hell an SSD is faster :D
Front
Defective MB and PCI-E boards mounted
Showing ATX backplate held in place by old 3.5" HDD magnets
Alot of alu needs to be cut away to make a nice clean look.
Picked up the ASUS MAXIMUS V FORMULA today
Itzi bitzy water channel size for that VRM cooler, will have to make a parallel loop for that
The beast is in its place now :D suits it well I think
ATX backplate now in place as well, will epoxy it after I finish cutting out the back, and offcourse finish sanding grinding & painting it
Final pic of the day.. Lovin' the ROG theme
As allways hope you enjoyed it
Cheers
/MrAhlefeld
Small update
RAD Planning
RAD Planning
RAD Planning
/MrAhlefeld
Even more updates !
Back end cut out and fitted.
Atx backplate got a little love with the angle grinder and a good old file.
Need to sand and prep it for paint as well.
Original vent cover met my trusty hand saw and other hand tools.
Add it all up and you get this.
Random shot.
Inside.
Inside closeup of atx backplate and vent cover
As allways.... hope you enjoyed it :)
/MrAhlefeld
Got the backplate back from the paintshop :thumbup:
He made a small mistake with the coating (see if you can spot it) :thumbdn:
Good news.... ½ price :D
Anyways, as allways a bunch of pics for those who are watching / following :)
Prepping for epoxying (masking off stuff that does not want glue all over)
More prepping for epoxying (masking off stuff that does not want glue all over)
Backplate off (masking off stuff that does not want glue all over)
Backplate (masking off stuff that does not want glue all over)
Mixed up a big batch of epoxy and 4 minutes later :D (masking tape removed before epoxy dried) ;)
Epoxy curing, random shot
Epoxy curing, put the magnets back on for safe measure just for the night.
The day after.... Fan grill mounted (without screws for the time being)
Closeup of fan grill and backplate
Hole for the RAD cut in the bottom.
Back with motherboard mounted
Motherboard mounted, just had to see
That's it for this weekend.
Next up...... HDD Cage
/MrAhlefeld
Stardate 15-10-2012
Progress report....
HDD Cage mounted
Alu mount for pump fabbed
Hole for PSU done
Pump relay wired up for direct connection to mains power internally. Connection to PSU via modular cable, and encaged in hotglue (a litte more needs to be done)
AC cord socket fitted to be inserted in the original socket. (back needs to be moulded in hotglue and painted as well)
Front panel cable fabbed
Whole system, all parts exposed ;) note that it's the temp MB that is mounted.
Hole for PSU
Alu mount for pump done (not mounted yet)
Power socket, Pump relay and AC cord.
Cable for front panel fabbed (USB - AUDIO - POWER BUTTON - POWER LED)
That's what i've been up to lately but not updated you guys on
as allways hope you've enjoyed it.
/MrAhlefeld
Incremental update 1.
PSU / PUMP / RELAY / AC Plug / AC Socket all wired up and encased in hotglue
Pump, Relay, Modular cable for relay/psu, AC socket, AC Plug, cables'n wires... :)
How it's all connected up 1
How it's all connected up 2
That's it for now, more done allready but not documented yet...
/MrAhlefeld
Fun with Alu and Copper
The VRM block requires a tight bend (no hose can do 90 degrees bend in 1.5cm) but with a copper insert it can :D
Made some HDD mounting brackets in Alu and epoxied modded original drive-mount screws to them
Mounted with HDD
That's it for now... more to come
/MrAhlefeld
So I have done alot of work on this thing, snapped alot of pictures so it's time for an update.
Pump mount - Silicone curing - Booring took ages to cure (1.5mm a day)
Powersocket epoxied in
Powersocket from the outside
PSU wired up
PSU wired up 2
Upper case assembly mounted
Love those HDD Brackets
Pump base done and mounted with rivets to the bottom of the case
RAD Mounted
PSU hole - Now filled
i7-3770K
i7-3770K in the socket ready for TIM
Fast forward.... GFX mounted - loop building in progress
Loop building
loop building and vent cover mounted
Rear complete !
That's it for now, waiting for a few bits and bobs before I can get the rest done.
/MrAhlefeld
Update!
So this rig has been up and running for a week now. I guess it was about time i posted an update on the whole thing.
Remember I said (up and running) so it's complete but not quite done yet, there are a few details that need to be sorted.
So without further ado.
Filling the loop
Random shot
Random shot
Enter H2O and Ethylene Glycol
After one week of running
Damn autofocus !
The whole system in it's glory
Bottom's up!
Showing off the rear
Pic of pump assembly - Silicone anti vibration thingy I made - Pump Alu bracket
Closeup of Pump - Res
Closeup of CPU - VRM
Closeup of RAD
Can you spot the mains power cable ????
Random shot
Showing off Rad clearance
Showing off RAM clearance
Well I guess that's allmost it for this project, it's been fun and tiresome.
But... Well worth the time spent!
Cheers
2017 System Rehaul start !
Delidding the i7-3770K
Using Der 8bauer Deliddie Mate 2 - It was ohh so easy ! no snapping sounds at all :)
Cleaning it up and remounting the IHS with CLU and High Temp silicone.
Left it to cure for the night, came out great looking and huge temp decrease as everybody else who has delidded a CPU
More pics
Rebuild Top and Bottom Radiator with new PWM fans
IHS sanded with 1200 grit wet sanding paper and CLU added to IHS and CPU block
RES planning and epoxying holders for RES, sorry for the crappy picture quality...
Old GFX card used as a temp for size.
The keen eye might see my diy LED strips, gotta love china for cheap parts (y)
1080Ti Let's tear it down and mount those GPU blocks... Yes one for each side :D Active VRM cooling
Grease it up good with that Thermal Grizzly Kryonaut
Ohh and I shunt modded the card as well before mounting it in the case, but the pics got deleted by mistake :S
Mounting stuff and planning at the same time.
Messy workbench :D
Ready to fill and bleed air from loop... Took ages !
Now I just need to take some proper shots of the system after completion (has been completed June 25th) guess im in no rush :)
I've use the time since to tweak and install a dual boot Windows 10 Pro and Mac OS Sierra Hackintosh. The last part is just for kicks :D
