Sedriss said:HL2, Far Cry, Doom 3, WOW, CoD w/ max settings, plus im looking ahead to like BF2 as well.
aZn_plyR said:see....HL2 x850xt wins by margin, Farcry the 6800ultra has more features and loses by 2-5 fps and has hdr if u're interested, .
ray4389 said:ATI is awesome but I don't knwo if the price is worth it. I still say get 6800 SLI setup. Sweetness!
Sedriss said:Am I still gonna get good performance with the X850XT in like Far Cry and what not? Also should i be worried about SM3 with the X850XT?
swatX said:if u arent building the system for another month then might as well wait for ATIs r520 core
James Earl Ray said:SLI sucks, buy this. X850xt
Sedriss said:Sorry, but I dont trust Sapphire as a brand.
freddiepm61 said:wrong.
get the ultra, and then go sli soon.....
sli may suck (it does not), but put it this way.
centvalny said:And this with bba x850xtpe oem with stock hsf...which sli can't compete
aZn_plyR said:lmao....dumb.....that is 3dmark01 and that is a fx-55 at 3.4ghz....woohoo sli can't competethrow sli'ed 6800ultra's on that thing and the same fx-55....yeah..
you buy a 6800 ultra now.....you then get another in a years time cheaply, which effectively doubles your performance (as by that time, graphics will have moved on, and gpu will be the limiting factor, not cpu, which is the main reason why sli is 70% as opposed to 100% improvement)
f
Hate_Bot said:SLI is still a waste. a X850XT-PE (OR Ultra) with an FX-55 would be my choice, rather then dual 6800GTs, with an A642800+...
aZn_plyR said:actually..an fx-55 is a waste..no offense to you fx-55 owners...
i rather have dual 6800gt's and a winchester athlon 64 3200+ and only mildly overclock the 3200+ but they do overclock like mofo's anyways... and this will be the same if not cheaper than ONE fx-55 and a single x850xtpe or 6800ultra and will be ALOT faster too.
erorr404 said:Check this out, it may change your mind.
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=1213309&Tab=2&NoMapp=0
Hate_Bot said:and a 6800gt sli setup is worth it?
bboynitrous said:My thoughts exactly. Just get a single 6800GT and end it all. Good price, good speed, good compatibility.
Hate_Bot said:Why? Sapphire is one fo the most trustful ATI Brands, they are like the equivilent to EVGA for Nvidia.
