Power Usage Question
budec
I'm building a system and trying to use as less power as possible (to lower monthly bill)
I'm planning on building an Atom 330 server. I have a choice between a 300W and 400W PSU. Both are 80%+ (80 PLUS Certified). Does the wattage matter or just how much the CPU/components are taking?
Anyone know of a 80%+ PSU that is 200W or lower?
Well for a system with that low of power usage, you might look at PicoPSU's which are close to 100% efficiency, and better suited to low-power situations.
80watt would be plenty I'd think. and about ~$40-50 with a brick.
But it also depends on how many drives you're planning on using... it wouldn't be good for too many drives... 1-2 drives it'd be fine... but beyond that I wouldn't use a small pico-psu
Also, if lowest possible power consumption is a goal, you might want to look at the next gen Atom/Pineview platform (Google "Intel D510MO").
Only the DC-DC part is close to 100%. You still need a 12V source to feed the PicoPSU which can be efficient or inefficient depending on the specific power supply used.
As a rule of thumb, PSU's tend to get less efficient the less they are loaded (as a percentage of max wattage). I believe, however, that the 80PLUS certification requires that the PSU must be at least 80% efficient at 20% load, or better if it's 80PLUS Silver or Gold. That works out to 60W for a 300W PSU. I'm not sure if that load is measured at the wall outlet or at the DC output though. I'd go with the 300W or better yet the PicoPSU w/ a good quality power brick.
It's the DC load. +1 on your suggestion. At the end of the day though efficiency will probably be fairly similar, power bricks won't be more than 85% efficient and you lose a couple more in the DC-DC, so similar to a decent small 80+ supply, but you don't need any fans and the form factor is very small, which is nice.
