Power Supply
Is there a way to have two power supply's? without having to just upgrade the one? and can it be on the outside of the case itself?
As long as your soldier the right wires (or connect em, usually paper clip works) on the 2nd PSU's mobo connector it will work. So you can have X many PSUs connected to many different things im your computer, however they must all be either plugged into the motherboard or have the two motherboard wires connected.
I would not advise this unless you must because you need to turn both PSUs on at the same time, and if you forget, or one fails, it could have major consequences.
[Ninja Edit]: From case modding FAQ:
