Power Supply Grounding Question.
CDdude55
Do you have to plug the power supply into the power outlet to ground yourself? (if so does the switch have to be off or on or it doesn't matter?) Or can you keep it unplugged but still touch it and be grounded?
Yes you need to have the PSU plugged in for it to be grounded...
I am not sure if the switch "de-grounds" the PSU when flipped off though...
It shouldn't de-ground as most of ones I've seen just disconnected the Hot and maybe the Neutral. In fact I believe it against safety rules to disconnect the ground in any way while the device is still plugged.
So i can only ground myself when the PSU is plugged in and it doesn't matter if the switch is in the on or off position. right?
