Power Supply Fan Problems
cerebros
Hey! My friend's power supply was having problems and after a little tinkering we found that the supply's cooling fan isn't spinning well. Nearly all the lubricant on the fan has worn away. Otherwise the power supply still works fine. Any suggestions on a grease or lubricant to use on the fan?? Thanks!
Probably not the best but I use trombone tuning slide grease I have left over from when I played 3 years ago, heh :D
100% agreed, yeah it's not really worth it I just thought it was funny what i've used in the past in a pinch :p
