Power Buttons??
amohedas
I am using an old Sony Viao case to build a new system. The only problem is that the power button is not standard so the PWR, RESET, PWRLED, HDLED ect... won't connect to my new board.
The bottom line is that I need to find a set of power and reset buttons and the leads for the LEDs that connect to the board.
All this stuff comes with a new case, but can you get them separately too??
Would Radio Shack have them??
Thx
just buy a new case, it will be nicer than the vaio case, and it will only be like 20 bucks if you use the power supply from the vaio. IMO:D
