Potential Build
Potential Build
CPU: Intel i5 3450 €170,90, 3 years warranty
http://www.4launch.nl/shop/product/123741/
GPU: Sapphire Radeon HD 7870 GHz Edition OC 2GB €232,00, 2 years warranty
http://sapphire.zercom.eu/index.php?dispatch=products.view&product_id=182230
Mobo: GIGABYTE GA-H77-D3H € 89,00, 3 years warranty
HDD: WD Caviar Black 1TB 7200rpm 64MB SATA3 €90,50, 5 years warranty
http://www.4launch.nl/shop/get/p-4-productid-089275
Cooler: Stock cooler
RAM: Corsair XMS3 Series DIMM DDR3 1333 CL9, 8 GB (2 x 4 GB) €32,25 10 years warranty
http://www.hardwarewebwinkel.nl/com...air-xms3-series-dimm-ddr3-1333-p-1017576.html
Optical Drive: LG GH24NS90 €18,90 , 2 years warranty
http://www.4launch.nl/shop/get/p-4-productid-122935
PSU: XFX Pro 550W Core Edition €60,90, 5 years warranty
http://www.4launch.nl/shop/product/112436
Case: Antec Three Hundred Two €57,90, 3 years warranty
http://www.4launch.nl/shop/product/124103
Keybord: Logitech K120 €8,00, 3 years warranty
http://www.komplett.nl/komplett/pro...ergelijk&product_code=14309657&channel_code=3
Speakers: Logitech Z-506 €58,95, 2 years warranty
http://www.4allshop.nl/980-000431vergelijk
Headset: Turtle Beach EAR FORCE X12 €53,90, 2 years warranty
http://turtlebeach.zercom.eu/index.php?dispatch=products.view&product_id=171172
Mouse: Logitech G500 Gaming Mouse €47,90, 3 years warranty
http://www.4launch.nl/shop/product/080892
Total price: €921.10=$ 1,209.19
High-medium gaming, web browsing, and for study.
Not more than €1,000.00=$1,249.74
3) Which country do you live in? If the U.S, please tell us the state and city if possible. The
Netherlands
See list
Yes, a LG Flatron W2243S-PF monitor and a brother DCP-130c.
6) Will you be overclocking?
No
1920x1080
September.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
I don’t need Crossfire or SLI and Firewire. I do like USB 3.0 and SATA 6Gb/s. Onboard gpu and UEFI would be nice but is not necessary. So a good H77 mobo would be perfect for me.
Yes, Windows 7 Ultimate 64bit.
Not a big fan of Sapphire.
What's the price on a Hitachi 7k1000.d or Samsung F3 1TB hard drive?
You really should consider an after market CPU cooler if you plan on gaming. A CM Hyper 212+ will hardly add to your budget.
http://uk.hardware.info/comparisontable/products/130954-71734-95521 see for yourself, but it looks like the WD caviar black is a much better choice, WD also grants 5 years of warranty which the other 2 HDDs don't. If I'd get a cooler then I'd be Gelid Tranquillo Rev.2 http://www.techreaction.net/2011/11/07/review-gelid-tranquillo-rev2/9/
edit: why shouldnt i take the stock cooler?
Unless you live in a very hot environment, you should stick with the stock cooler.
So you know, we're not recommending the Hitachi 7k1000.d or the Samsung F3 HD103SJ over the WD Caviar Black due to their warranty time (which were rather recently reduced following their acquisitions by WD and Seagate, respectively). Those two drives perform as well as, if not better than, the Caviar Black yet they cost less.
