POST then nothing! Plz help
ryansebiz
I just installed my new Western Digital RE2 WD5000YS on my Main PC (specs in sig), set it up in XP, created a new volume and rebooted.
The computer went into POST like always but after that nothing. No Windows loading screen or anything – just a black screen (my monitors did not go into sleep mode). I tried finding my computer on the network from my laptop but it could not access any files.
XP is installed on dual Raptors in RAID 0. I accessed the RAID menu and the array is healthy and set as the boot device. I then tried unplugging the SATA cables of the storage drive and all USB devices and rebooted. Still no Windows.
I've tried disconnecting the Raptors and booting with the WD and after POST I get the "Boot disk failure" message (since Windows is not installed). Funny thing is, I don't get that message with the Raptors.
I tried pressing F8 and F10 to bring up Safe Mode but no luck. All I was able to access was the boot menu and RAID menu, but I cannot get into Windows.
RAM is Corsair XMS 2GB DDR400. Nothing is overclocked.
Fortunately I do have a backup of all my files. I’d prefer not to have to reinstall everything though.
Should I try clearing the CMOS? I haven’t yet because I don’t want to destroy the array in the BIOS. Would clearing the CMOS leave a healthy array?
Any other ideas of what I should try?
Go into the bios with all the drives plugged in and then set the boot order so the Raid Array boots before the 500 giger. I will pry be in the boot sequence menu.
Cooter
