p2653 is a stable work unit.
As such you will be able to run at higher clock speeds or with tighter memory timeing than with an iffy work unit like p2562.
If your going to be testing an overclock with a work unit, then you need one that will show you a difference between a very stable overclock, which is what you need for folding and just a good fast on.
Luck .........
