possible SNDS
Astroman
Been running by 2.4C @ 3.3 ghz for about 1.5 years now. Well, the IC7 max-3 burned up a couples weeks back so I did the RMA thing. put it all back together, no dice. I have to take my proc to fry's and strap it to a test bench mobo (carefully.. no IHS) to see if the proc went too.
I wonder, if the proc took the mobo, or the mobo took the proc.
anyway, if I need to replace it, what do y'all recommend? maybe a used P4? no sense in spending major dough on a legacy system eh?
or, what available proc should I get?
http://www.newegg.com/Product/Product.asp?Item=N82E16819116204
P4 505. Raise the FSB to 200 and voila! 4GHz. No HT, though.
Then for the board
http://www.newegg.com/Product/Product.asp?Item=N82E16813131534
So you'll be spending about $330 for a system that is highly likely to hit 4GHz on air, and also has a great upgrade path (Pentium D's, possible Cedar Mill / Presler if Intel doesn't drop the compatibility ball again.)
Now that I think about it, you'll also need DDR2 :\
I'm not sure what to say now.
or you could just go buy a cheap S478 CPU
get a newer revision 3.0e or 3.2e, theyll get 4ghz or close too. Id tell you to replace the board and cpu if I thought youd see a performance difference, but itll be minor at best.
