Possible motherboard problem?
i just built a new computer and everything is working honkey dorey until either i press the off button manually or i tell it to shut down via windows but either way the computer ends up restarting when i told it to turn off unless i hold the button down until it dies
i've looked over the f-panel and reinstalled windows with a different disk altogether and the problem persists past what could be seen as normal teething problems
the setup is
ECS NFORCE6M-A V2.0 Socket AM2 nForce 520LE 6 Channel Audio ATX Motherboard
AMD 6000+
Creative SoundBlaster X-Fi Xtreme Audio Soundcard
700w psu
2 gig ddr 800 (overclockers)
HIS Radeon x1950PRO 256 MB
and so on and so forth
any ideas?
oh and there is also another problem
while playing W.O.W. the character falls through the ground
the sound card seems to be causing this problem and disabling it and using the on board system sorts it out
but is there anyway i can make this sound card behave itself?
thanks
I have a similar problem. I uninstalled the Sound Blaster Live card card/driver and everything works great now, except the onboard audio isn't working! Yup! I enabled it in bios. I've addressed the issue with ECS and am waiting for their response. I'll let you know what I find out. Good luck!
I have the same issue with the motherboard. Can not turn it off without manually powering it off with holding down the power button (4 sec) or killing the power in the back.
Also, has anyone noticed when the system posts the CPU description is initally messed up and then corrected? I get some funky chars. then it changes to correct description.
Would appreciate feedback on either issue.
Thanks,
Gary
