I currently own a 19" 905DF and I am thinking of grabbing the second for dual monitor setup but if i do I will be wanting to mod them out of there housings to close the gap i nthe mouse crosover running extended display
Ive already removed most of the casing, but I have come across a concern and not enough background info to make an educated guess... I remember being told that flat CRT are wire wrapped to force them to stay flat.... but the screws holding the plastic casing front on are the same ones the wire wraps are arround.... has anyone tried this or know better info aboutthis, Im just the unlucky enough type to usually just try it, but knowing my luck itd wreck the monitor or something...
