PrometheuSBoxeR
- Sep 21, 2005
Posting a possible PC to come. What do you think when its all put together said and done. Overclocking, compatability, all around parts, alternative parts etc. and if you have any advice to my questions, great.
Case: http://www.newegg.com/Product/Product.asp?item=N82E16811112025
Lian Li PC-61Black - With all this hardware inside is this a safe purchase? Is cooling inside effective even though its only 4 80mm Fans? If I plan to watercool in the future is this case a option?
Mobo: http://www.newegg.com/Product/Product.asp?item=N82E16813136152
DFI Ultra-D S939 - Reading reviews it seems that the bios these things come with is a problem. I don't know how to CMOS bios or update them etc. am i going to be ok? I also heard you can upgrade to SLI modding this somehow?
Processor: http://www.newegg.com/Product/Product.asp?item=N82E16819103546
AMD 64 X2 4400+ Toledo Core - I have heard a lot of good about this CPU, using my computer for gaming and dvd encoding and burning and other misc apps.. I figured this was the right choice. Hopefully It will also help future proof my setup when Multi-Threaded games are popular.
Processor Heatsink: http://www.newegg.com/Product/Product.asp?item=N82E16835109122
XP-90C - As far as I know this thing is supposed to be a beast. All copper and such, pretty expensive but im hopping to OC the CPU nicly with this on air. I think there was another option I hear alot about a Zalaman cooler to cool the PC.. not sure about them?
Processor Heatsink Fan: http://www.newegg.com/Product/Product.asp?item=N82E16835180088
92mm Panasonic Panaflo - Heard only good things about them. Ive heard about these and Deltas? Not sure.
Video Card: http://www.newegg.com/Product/Product.asp?item=N82E16814130248
eVGA 7800GTX - Not sure why this one is cheaper then the others, the specs seem to be the same. It says retail so im not exactly sure. Looks good so far, 7800GTX's are beast. Mabey in the near future im looking to mod the Ultra-D mobo to SLI and hook two of these bad boys up?
Video Card Cooler: http://www.newegg.com/Product/Product.asp?item=N82E16835118117
Zalaman ZF700 - Reading the reviews on these things, they are supposed to work terrific. Get a nice OC on my GPU and keep nice temps while doing so?
Power Supply: http://www.newegg.com/Product/Product.asp?item=N82E16817104152
OCZ 520W PowerStream - OCZ makes quality stuff, this is supposed to be a rock solid PSU. Not sure how would hold up if I SLI 7800GTX's on it. Other then that this thing is supposed to be great.
Memory: http://www.newegg.com/Product/Product.asp?item=N82E16820146578
Crucial Ballistix 2GB (1GB x 2) - Heard alot about these things, supposed to be some of the best 1GB sticks money can buy. Hopefully can get a nice overclock on these as well and have them preform nicely as well. I was also pondering the 2GB set from G.SKILL they are fairly new released.
Harddrive: http://www.newegg.com/Product/Product.asp?item=N82E16822144185
Maxtor MaXLine III 250GB (x2) - Two of these bad boys I think will do nicly. 16mb Cache, nice storage, quiet etc. Im thinking of either 1 for gaming and OC and such, and the other for storage and media. Or i could always set them up in RAID 0 and see how that works for preformance right?
Drives: http://www.newegg.com/Product/Product.asp?item=N82E16827106988
Lite-On DVD Burner (x2) - I like to burn DVD's a lot, and these things can also read DVD's let alone burn. So im thinking whatever im doing i can always make use to both really. I would also like to be able to burn 2 DVD's at once, Saves me a lot of time and hassle.
I think that about covers it all. Again please tell me what do you think when its all put together said and done. Overclocking, compatability, all around parts, alternative parts etc. and if you have any advice to my questions, great.
PS: The Total comes to $2200.00 on Newegg.
PrometheuSBoxeR
PrometheuSBoxeR
