Astronomica
- Sep 18, 2008
Over the past month, I've been getting some seriously poor downstream signals. I called up comcast and had a tech down to take a look at it. Of course, during the hour he was here the line was as perfect as it ever was. He replaced my docsis2 modem with a arris docsis3 modem and left. I've got 1 clean line coming from the hub outside, directly into the house. The only split in the line is in the cable box, thats connected with a coupler. Is this possible to fix myself, or is it a problem with the entire node. I assume its from the cold weather, but i thought comcast had something in place to boost the signals in the event of cold weather. Heres the screencap from my modem.
As you can see 1 and 4 are the problem. Any cable guru's to shed some light on me?
![11t9ybr.jpg](http://i54.tinypic.com/11t9ybr.jpg)
