PolarFlo E Block
Dont get that block, it isn't that great performance. For the same price you can get the very nice Swiftech 6000 series blocks. They also can be upgraded with a simple metal bracket that would probably cost less than the replacement top for the Maze4.
The PolarFlos appear to perform about the same as, or a little worse than, the DangerDen RBX. I say "appear" because no-one has really tested any PolarFlo equipment properly. I offered my TT to SystemCooling.com for testing, but they wouldn't even look at it :(
In any case, that $12 will get you a big performance increase over youe Maze-4, with only a little more restriction. Unless you're running a pump with no balls at all, it should do the same or better than a 6000 and much better than a maze-4.
