Points Not Showing Up
Hito Bahadur
[H]ard|DCer of the Month - December 2006
All,
I sent in 2 tinker cores this morning at around 7 AM. The logs show that they were successfully sent. It's now 12PM and their points still haven't shown credit. Usually updates post between10-30 minutes after sending in the results.
Any ideas? I hate to throw 482 points down the drain.
is that a 5hour difference?
extremeoverclocking only updates every 3 hours. stanford updates more often.
stanford shows the last WU as yesterday at 2:37PM. i'm not sure which time zone, though.
so they haven't shown up on stanford yet. i'd just give it some time.
the only reason i can think of that they wouldn't show up is they were inaccurate, or they have to be checked because someone else was inaccurate, or something like that.
Maybe, kinda strange. It was a 5 hour local time difference. They should have showed up on the 1000 Eastern Extreme update and before that on the Stanford and there was no error showing up in the log or during the computing.
if the result came back different than what they'd gotten from other people doing the same unit, then you may not have seen any error messages but it still could be wrong.
i guess you'll just have to wait a bit and see what happens, though.
Did they go back to the server you got them from or to a backup server.
If it was a backup server then they will need to get the main one running again before they can find out who got sent what and credit you with the points.
Luck........... :D
I have had points take a day or so to finaly post. I wouldnt worry to much since the log file
shows everything was ok.
It gets nervewracking when I'm now up to 800+ points today that haven't posted.
