Hi to all, I would like to buy this Case
http://www.silverstonetek.com/products/p_contents.php?pno=LC13-E&area=usa
To fit my VGA I will remove one box of 3.5" and I would put in the place of one 95mm Fan.
Another 95mm Fan is in the box with the HDD
Here the image:
I would like to use also the side grid to put fresh air on the CPU with a 80mm fan
In the back there are 2 80mm fan that pull out the hot air.
I think to use also the fan of the power supply to pull put other hot air
Here the diagram of mine mobo with the connection for the fan, could you help me to find the best solution to use it?
Some Connector don't have the sensor or have a on off pin, what does it mean?
Could you suggest a good fan 80 and 95mm silence and powerful?
I need to change also mine Cpu cooler i have an Am2+ processor.
txxx
p.s. here one review of the case.
Here the image:
txxx
