Hey everyone, well I don't exactly know how to explain the situation so...I'll just start describing what happened..
I was trying to OC my Opteron 170 (has a Scythe Ninja), and I was following the instructions that Eclipse posted. I completed the first two steps and then decided that I was just going to run a ram divider, as I don't have a floppy drive installed, so when I found out the max my CPU and HTT could do (which was 2.4ghz), I went into BIOS and set it to 235 (I had an error in prime95 at 2.4 but at 235 I was fine), set the ram divider, saved to CMOS, and then tried to boot into windows. Then it restarts (usual) and nothing shows up on the monitor, I was getting a "No Signal", it happened once before, so I just turned of the computer and it worked fine then, and now its still saying "No Signal"
Any ideas? I decided to hop on here before I go and mess things up...
Please help!!!!
Edit: I swapped in my old Geforce 2 MX400 and nothing shows up still..I'm assuming this is a processor related issue?
Please help!!!!
