Please help me pick a fan controller
hunter33
I have an X-Qpack case and would like to hook up the CPU fan and case fan to a fan controller. The stock fans are pretty quiet but the case is on top of my desk right next to the monitor so there is still a little noise. I never use the floppy drive or 2nd optical drive, so the fan controller can be 5.25 or 3.5". The case fan has a 4 pin molex connector and the CPU fan is 3 pin. I was hoping to find a fan controller that also had USB & SATA connectors and a card reader on it. I don't have any spare audio or firewire headers so it would it would be better if they weren't on the faceplate. Does anyone make a fan controller or card reader with the following features only:
fan controller for at least 2 fans
USB port(s)
SATA port
card reader
Thanks
Thanks. I've done quite a bit of research today and haven't found just what I'm looking for. I never use the floppy or 2nd optical drive, so maybe this is a double multi-function solution. I'm thinking maybe a card reader/USB hub for the 3.5" bay, and a nice fan controller for the 5.25" bay.
