Please help..BIOS fash... *cries*
2Fresh
Well, it flashed fine, but then when I rebooted the rig would not start up. I used the latest at DFI-Street.
I have an Ulta-D LanParty, the bios said LanParty NF4, so I assumed it would be ok (yeah, never assume) I guess it is not..Now what in the FRACK do I do???
Any help would be great.
Thnx guys
you're not entirely screwed even if you did ruin it, you can get a new bios chip mailed to you from DFI then you just pop it in like a lego
Boot up holding down the insert key on your keyboard. It should boot using fail-safe settings. Go in, load defaults, and reboot. Go back into BIOS, and set it up how you want.
I just pulled it out and sent it in, dropped it off this am. Did not know what would be faster..waiting for the new bios chip or just sending in for a fix.
I have gotten the same info about the bios and how to try and save things, as above post states...I really do not uderstand how a clean cmos can fix a bad bios, or install.
Anyway, thanks for the input guys.
Lazn_Work said:
If time is of the essence, you can pay the extra to have one express shipped from www.badflash.com
$40 that way though.
==>Lazn
That's kind of crazy on the pricing. I can see it if you have a motherboard in the $200~$300 range, but if you have a $100~$150 it's probably more cost effective to just buy a new board.
True, also if you get a similar enough board, you can use it to fix your old BIOS (via HotFlashing)
That really is just for people who can't wait and need to fix an expensive board.
==>Lazn
