SJetski71
- Sep 6, 2002
How is the input delay?
OP i'm not sure if you saw it, but the plasma input lag thread has some updates, results for the Samsung D550 are included. Note that a laptop was used for comparison which adds 10-16ms to the actual results, which would explain the number posted by Orta in that thread. Here's the original thread the tester posted, notice that he did not take into account that using a laptop skews the results, and that windows Aero apparently skews it a bit more. Maybe it isn't as low as you wanted but seems decent so far.
I wonder if the VGA input accepts 1920x1080 and how much the results would vary if so, it may even be a whole frame faster.
You've explored the topic well so far, and we are all learning something here, but have you tried posting at the AVS forum yet? I'm thinking it may fill in a couple more pieces of the puzzle for you, maybe start a new thread there, in addition to posting your thoughts in that input lag thread. I'm more than willing to bump your topic to try and stir some discussion...
