I have a phase change unit and a watercooling system. What I am wondering is if I can merge the two to get better results from the watercooling on my GPU's (with the probable downside of slightly worse results for the CPU).
I have thought of a number of ways of doing this, all involving using the phase change unit to cool the water, and I am wondering if anyone has tried something like this, or heard of someone who has...
1.) Directly cooling water in a reservoir with the phase change head.
Possible issue: would be potentially frozen water (and busted resevoir).
Possible resolution: Anti-freeze instead of water, though that might be a whole other set of issues.
2.) Directly cooling the radiator by attaching the phase change head to it.
Possible issue: Frozen section in the radiator restricting water flow.
Possible solution: Use a large flat piece of copper to spread the cooling more evenly.
3.) Indirectly cooling air that is then blown across the radiator. This would be done by attaching copper tubing in an appropriate patter to the phase unit and then blowing air across the tubing and then across the radiator.
Possible issues: Frozen or condensation damaged fans, unstable, ugly, possibly labor intensive making the tubing.
4.) Connect a CPU water block directly to the phase change and simply run the water through the CPU block with no radiator or resevoir involved?
Possible issues: Frozen connections, Frozen water, Leaking due to expansion of metal fittings, frozen plastic tubing that becomes brittle and breaks.
Possible solution: Massively high quality fittings, anti-freeze, and some kind of expensive cold resistant tubing.
Anyway, I am just curious. Anyone have any ideas or knowledge on this subject?
