I'm having problem with my pfsense. I've setup a 2nd pfsense machine with carp on it's own network. I have the following interfaces:
WAN (outside IP)
LAN (10.1.0.0/16)
CONTROL (10.2.0.0/16)
PFSYNC(10.8.1.0/24)
All of interfaces on both machines are showing master and it's causing me some headaches. On the master the base is 1 skew is 0, slave base 1 skew 100.
###Master###
The High Availability Sync settings:
Synchronize States - Check
Synchronize Interface - PFSYNC
pfsync Synchronize Peer IP - 10.8.1.3
Synchronize Config to IP - 10.8.1.3
Remote System Username - admin
Remote System Password - (password)
Everything below is checked.
###Slave###
pfsync Synchronize Peer IP - 10.8.1.2
Not sure what else needs to be set to make this work properly or where to look to try to fix this problem. Any assistance would be awesome.
Running on ESX5.1 containers, the ports on the vSwtiches are all in promiscuous mode that are for the pfsense machine (all the others are set off).
WAN (outside IP)
LAN (10.1.0.0/16)
PFSYNC(10.8.1.0/24)
###Master###
###Slave###
