Hey, First Post here, long time lurker.
Need to replace one of my drives on my Perc5i as it has failed. It's a 1.5tb drive which are hard to source now-a-days so i'll probably just throw a 2tb in there.
My question is how do I locate which drive is which within my system? If I unplug the wrong drive then my raid5 will be compromised and go down, ya?
I just want to make sure I swap the correct drive and don't create more issues.
I plan on backing up my data before hand but if you can suggest an easy way to ID the drives that would be a big help.
Also, whats the best app to test transfer speeds and what should I expect from my perc5i in terms of numbers? I just want to make sure everything is working flawlessly when it's back up and running. I have a BBU so I use "write back" or whatever the option is called (away from my system for a week so I can't confirm)
thanks!
thanks!
