Pentium M FSB
BossNoodleKaboodle
I was looking through Everest and came across something perplexing. Why does it say my effective FSB is 100Mhz? Shouldn't it be 400? 100QDR?
Field Value
Motherboard Properties
Motherboard ID 12/16/2004-i855GME-W8362-6A69YABBC-00
Motherboard Name Unknown
Front Side Bus Properties
Bus Type Intel GTL+
Bus Width 64-bit
Real Clock 100 MHz
Effective Clock 100 MHz
Bandwidth 800 MB/s
Memory Bus Properties
Bus Type DDR SDRAM
Bus Width 64-bit
Real Clock 167 MHz (DDR)
Effective Clock 333 MHz
Bandwidth 2667 MB/s
Chipset Bus Properties
Bus Type Intel Hub Interface
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Effective Clock 267 MHz
Bandwidth 267 MB/s
Probably Everest is just being gimp. Try to run a memory benchmark test. If Everest is correct you shouldn't pass about 800MB/sec throughput (try Sisoft Sandra for this)
BossNoodleKaboodle said:
everest's benchmark says 2500MB/s for memory read and 600 for mem write... latency is about 10ns
10ns? Holy christ. You must have ram with negative timings! It takes a really good Athlon 64 FX/UTT combo to even begin to touch 30ns
I think your score is average and fine for the read/write.
lol sorry it was an error i meant 100ns
Negative timings would actually mean that his ram is going faster than infinite cycles per second, that aint happenin tho. lol. dude im bored, 100ns, thats kinda slow
Damn, and I was happy with 59.5ns@3.9GHz on the Max3. On the other hand my entire rig cost less than a current FX :)
My $300 3700+ and $50 TwinMOS SP did this
That's sick! What type of cooling are you utilizing?
I was gonna get some of that cheap UTT myself (it's everywhere!!) until I discovered that the 875P tends to hate those chips (even if mobo applies adequate juice). I will get a 4400X2 when the prices come down a bit, prolly running a DFI nf4 with 2GB UTT.
and again, very nice!
Air cooling on both the CPU and ram. For CPU, XP90C. RAM, an 80mm fan and an exhaust blower.
The ram is now in Canada (or at least should be by now), along with the board. The 3700+ went to San Diego. The XP90C is sitting pretty on my X2 4200+ now.
Ur latency settings are so low, but they dont seem to be giving u much benefit over mine.
slamgoku said:
[IMttp://i4.photobucket.com/albums/y143/slamgoku/notbad.jpg[/IMG]
And yet they still won out.
Still, that's pretty good latency there for TCCD.
well they won out but im also on a dual channer controller which usually causes the latency to be somewhat higher
I need to get Everest and see what my system does latency wise.
It had to be really low when I was running 300FSB with ram at 2-2-2-5 (and 3:2 ratio)
