Souldrinker
- Jun 28, 2007
Hiya, its about high time for my trusty computer to go to surgery for a makeover, however its been awhile and I'm out of the loop. I've been using this site and its forums for years (ever since stumbling over the ratpad) and couldn't think of a better place to get input and opinions.
With that out of the way, some tidbits before I get to the fun part:
-My budget is roughly 1200 bucks.
-I'm primarily a gamer and meddle with graphics on and off.
-Typically my machine is on 24/7 so quality, power preservation and noise level are important.
-I don't know how wise overclocking would be, keeping the above point in mind but am not opposed to it if I won't fry the system over time. Input welcome.
-I can't afford full makeovers every few months so prefer choices that can last awhile.
-I rather spend 20bucks more and have quality than wait for a carcrash to happen, so to speak.
Ok, with all said and done:
CPU
I've long favored amd, but nowadays intel's just looking better. Keeping the pricecuts in mind (I'll hold off the purchase until then), I've looked at the E6750, perhaps the 6850 variant. Going along with this, I honestly don't know which heatsink to pick for the chip.
Motherboard
I favor Asus boards but quite honestly have no real clue which to go for. I do not intent to use sli, however I'd like to keep it an option for the future. Plus, changing mb's is a royal pain. I intent to recycle my hard drive even though its cranky ide style will probably be the new systems weakness and eventually make room for a sata, but I believe most boards these days support both anyway?
Vidcard
Again I favor Asus models and have looked at the 8600gts top, but is the innate overclocked speed of the card really worth it? The 8800 models are pretty expensive, yet the 320m model is not too far off in price.
Memory
Corsair is my ram of choice, 2gigs are plenty. The 8500C5D (dominator) series looks nice and shiny but do I really need that, or would the 6400C4D (dominator) suffice? I figure the higher mhz rating only really comes to play with overclocking?
Power
As stated, I run my comp nonstop and this thing makes or breaks it. I've been using enermax with mixed results in the past (good ratings, quiet..but one blew up on me after a year). Currently I'm partial to the new corsair psu's as many seem to favor 'em and I wager its for good reason. Plus from what I read, the efficiency, quality and noise all seem great.
However, how much power do I really need? With all the above, I run a hd, cd/dvd drive and anywhere from 2 to 5 case fans in my cm stacker. I used to run all, but scaled down after my first psu blow up (hastility bought replacement didn't have enough connectors).
I don't have or need a lightshow inside my case, it just has to run, keep cool and quiet
I'm more the type that leans towards efficiency over flashiness. Drawing too much power would just drive up my electricity bill and thats high enough really..so, I don't know where the line between "overkill", "needed" and "needed plus comfort zone" is.
Phew, alot of writing, thanks for lasting through it. Everything I left out will be recycled as it is either fairly fresh, or still good enough. I probably busted my budget with some of my thoughts but..yea, any help advice or suggestion is welcome!
CPU
Motherboard
Vidcard
Memory
Power
