PE or regular XT
chuckm1020
I was wondering if anybody knew what my video cards was. Since ATI tool doesnt support this new core thats used with pci express i cant find my clock speeds.
Thats what that shows. I just want to know if its the regular XT or the XT PE
edit: oops i didnt mean for the picture to have all that white, my bad :D
Not too informed on ATI stuff or PCI - express but maybe 3d mark (the end result) or sandra or something which might show you the core speed
So far as I know, only the AGP version of the X800 XT carries the "Platinum Edition" moniker. The PCI-E running at identical speeds is simply the "X800 XT".
Edit: The "System Info" button in 3dmark 03 should be able to tell you your speeds...
AGP XTs are PEs, whereas the PCI-E XTs are just simply XTs. That's what I always thought, but I could definitely be wrong.
554b = x800 se
5549 = x800 pro
5d57 = x800 xt
554a = x800 xt pe
does overclocking etc work with atitool?
