Bandalo
- Dec 15, 2010
While you might have some signal compatibility for future cards, there's no way they can provide POWER compatibility. If the new spec allows 300W, then only new motherboards will support the 300W cards. You'd fry a PCIE 3.0 motherboard if you tried to pull 300W from the slot alone.
