PCI riser card...
Steve_Oaks
Does anyone have a pci riser card..and if you do did it come with software for configuring it? I bought a rack mount case off ebay and it has a riser card. In the instructions they tell you to use a piece of software to help configure its jumpers to assign irqs.
http://www.ms-systems-online.de/download/IPC2U-Installation-Guide.pdf
I can get the network card and video card on two seperate irqs but the nic just does not want to work. Which is strange because I had it working with no configuration except plugging the cards in a week ago. But then the os hard drive failed so I had to reinstall 2k server.
