PCI-eh?
Zero1
Hey guys.
Not quite sure where to place this thread since I don't think it's specific to AMD or Intel boards; it could even be a RAID card issue, but let's get to that.
The motherboard I have is a DFI Lanparty SLI-DR Expert. A decent board. In my 16x PCIe slots I have a Radeon X1900XTX in the first one, and an Areca 1220 in the second one. With this configuration, the graphics card theoretically runs at 16x, and the RAID card at 2x. I was running some HD benches, curious of my array speed and I found it rather odd that it seemed to be hitting the wall at ~190MB/s. In truth I was expecting 220-240MB/s. I grabbed HDTach and got this result:
http://img511.imageshack.us/img511/1364/untitled26ob.png
As you can see, the burst rate has maxed out at 194MB/s, and the read speed tops out at a similar speed. Isn't PCIe 2x supposed to be in the region of 500MB/s? I find it odd that my transfer would max out at ~180MB/s.
I went and fiddled around in the BIOS, thankfully there is an option to change how speeds are assigned. The default configuration in single VGA mode is 16-1-1-2 (16x,1x,4x,16x), meaning the first PCIe slot gets 16x (for the GPU) and the other 16x slot gets 2x. Now I went and changed it to the same config as it would use for SLI, which would be 8-NC-4-8. I booted back into Windows and benchmarked again:
http://img61.imageshack.us/img61/9486/untitled39gw.png
Hell yeah, that's a bit more like it. The drives aren't hitting any walls as such, other than their own performance, and the burst speed is good enough to cover the max throughput of my array, iRAM and single HDD all connected to the same card at once.
But hold on, 740MB/s? This is an 8x PCIe card, am I wrong to expect a faster burst speed than that? Maybe I am, just because the card is 8x, doesn't mean I will get anything like 2000MB/s burst rate (even so, I only "need" ~480MB/s I guess).
Something seems really amiss here guys. I'd appreciate a hand, maybe there is some PCIe related setting in the BIOS I should check? Perhaps this is the nature of the RAID card? I'm kinda dissapointed right now.
Thanks in advance.
