PC will turn on but not boot help!!
Just got a new board went against my religon and bought an Asus P4S800D-X w/ a P4 3.06ghz cpu. Got it installed everything and the thing will turn on but not boot up (monitor will not come on) Monitor does work because I use it with my laptop. So i thought maybe it was the video card so I went out and bought an ATI 9550 still does the same thing if you have any ideas please help thanks.
First off, try botting with just the essentials, install one stick of ram, video card and a hd, try booting it and see what happens, if that dont work, install a different stick of ram, keep going until you install something that makes it not boot, viola, you've found the problem.
Keep us up to date. ;)
any beeps, diagnostic lights, etc? all power to the board connected?
take board out of the case and set it up like the above post, ie cpu/vid/1 stick ram and try to stoke it up.
nope no beeps just lights up like everything is running but nothing is coming on the monitor i wonder if the agp slot is bad anyway to tell?
For a start disable the lines you dont use on your BIOS.
Are you using Fast ram with tight latencies? Give us your exact spec.
Also did you save your configurations and then continue?
Your BIOS version and does it support your CPU's FrontSideBus?
It can be the same skt but the FSB is not supported like 945chipset does not support Conroe.
is the cpu fan turning? is the 4 pin ATX power cable connected? are you sure u got all the system power connecter right? hdd power, reset sw, pwr button....etc.
yeah from the looks of it all the connectors are right (is the pos of the connector the one with the arrow on it?) and the cpu fan is turning. Its not the agp slot because i just went out and bought a PCI GForce FX 5200.
I'm having the same problem with my ECS motherboard (sig). Also s478, same exact problem. Everything looks fine, turns on, but it wont boot. RMA'd it and got the same problem in the second one. I think it's ECS fault and not newegg. BTW did your motherboard come sealed? Both of mine didn't come sealed. I was about to get that Asus motherboard since I figured I can always trust Asus....now i'm confused. IS THERE NO s478 WORKING MOTHERBOARD ANYMORE?!?!?! The one I got at compusa (some sorta gigabyte) worked but it was $160 after tax and all. So I returned it after testing that all my stuff worked. Can anyone recommend a good s478 working motherboard for under $100?
I've been rocking an MSI MAMP4 board for a few years now. I paid $60 for it new, and it's no show pony but it works great and is very stable. APG4x :( and crappy VIA chipset :( but all things considered, I get pretty good performance out of it and my 2.0ghz northwood
