PC tool kit?
harsaphes
hi, any suggestions for a tool kit?..im looking to get someone, one as a gift....ideas on where to buy and or make/brand?
thanks
tool kit? My only tool kit is 2 single cross-head screwdrivers. One with a long neck, other one with a short neck. lol.
The "ToolKits" I have seen so far are kind of not so good. You could get several tools and put then in a box and make a great kit. Here is a good beginners kit.
A PS tester
http://www.svc.com/ps-124.html
A digital OHM meter
http://www.svc.com/dt830b-12.html
A power connection pin remover set
http://www.svc.com/pmtk.html
probably a couple of inexpensive needle nose pliers and cutters
And if ur really fancy my favorite tool in the kit
http://gallery.bcentral.com/GID4308581P4858169-CORDLESS-TOOLS/Cordless-Screwdriver-Kit.aspx
I like that power supply tester!
-Larry
A PS tester
A digital OHM meter
