PC randomly shuts down
KoolDrew
Just recently I overclocked the computer in my sig and it seems perfectly stable. It runs Memtest86+ for 3 hours, SuperPi 32M, Windows Memtest for around 12 hours, 3DMark, and SP2004 for 24 hours. All without errors or any problems. Now just today I simply open up a video in MPC and it randomly shuts down. Is it normal if an overclock is too high to just shut down like this? Is it as simple as my overclock is too high and lowering it will fix it? Could it possibly be my PSU?
I know their are a lot of things that could cause this so I'm going to have to narrow it down, but if you guys could just start me off and help me out it would be greatly appreciated.
The first thing your going to want to try is taking everything back to stock, and see how it does. From there you can start to narrow down the possibilities. But like I said, try running everything at stock speeds and see how it does.
Well, before I started overclocking it I did not have this problem. So I kind of know it is because of the overclock, but just want to make sure that shutting down is normal if your overclock is not stable. I've heard of getting BSOD's, rebooting and stuff like that, but I wasn't sure about completely shutting down. Would you suggest I just move the HTT down 1MHz and see how it works and continue doing this until it does?
