Hyper_Lite
- Jan 19, 2003
I just built my new system and I'm having a couple issue's. Hopefully someone can help me out.
I had a P4 3.0 system previous to this one. I kept the optical dirves, hard disk, audio card, case, and psu. Everything worked great on this system, I didn't have a single problem.
Well I decide to upgrade and move back to AMD to give their Athlon64 processor a whirl. I install all the parts and everything seems to be OK. Now about a week later some things start showing up. I have no idea what it could be, and I'm thinking about RMA'ing the motherboard and getting it replaced. When I boot up the PC it will work every other time. The bios boots, and it starts to launch the OS, but it doesn't. I reboot and it's fine, if I reboot again it does the same thing. Then while in Windows accessing this single folder takes about 20/30 seconds and all the other folders load fine. Sometimes while in games while changing options it will lock up, but I've never had a problem while in the game. Does anybody have any idea what could cause this?
New System:
AMD Athlon64 3500+
1GB Cosair XMS PC3200 Memory
MSI K8N Motherboard
NVidia 7800GTX Video Card
2 optical drives
120GB WD 8MB 7200rpm HD
420Watt PSU (TTGI)
New System:
AMD Athlon64 3500+
MSI K8N Motherboard
2 optical drives
420Watt PSU (TTGI)
