Hi,
Im currently in the market to upgrade my system. I currently have an FX-60 AMD at 2.6ghz along with 2gb of ram and 1 7900gtx. I have about a $500 budget to work with right now so I have enough to buy a Q6600, MB, and 4 gigs of ram. Some questions:
1. Am I going to see a very significant performance increase going from an FX-60 to the Q6600 at stock speeds (2.4ghz) even though the FX-60 has a high clock?
2. The Q6600 runs at stock 2.4 ghz... I have no expereience overclocking and a moderate PC know-how. Is it hard to overclock to 3.0ghz and can I do it without cooling? It seems the Q6600 is such a great value due to it's ability to overclock high. I just have a normal black PC case that has a Silverstone fan in the back and it keeps my current rig fairly cool... will this work ok with a Q6600 or will it run even hotter?
3. If I get a 775 MB that means I can upgrade in the future to the Q9450 or Q9550 right? Im guessing the new quads coming out after that won't be 775 socket?
4. Am I wasting my time if I don't get a new videocard (prob 9800gtx) until Christmas? Im guessing the 7900gtx is going to bottleneck me good. They are getting cheap ($300) so I may not wait until then however.
5. I had a friend build my current rig and we don't really talk anymore so im going to be building this by myself. I have decent computer know-how... is it difficult to take current MB out and put in a new chip?
any other input is greatly appreciated....
