Build specifically for my parents (so basic internet use)
4-500 ideally (can go upwards of 600 if need be)
3) Where do you live?
CA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
EVERYTHING
NONE
6) Will you be overclocking?
No
My parents have a 40 LCD tv (i believe it has couple of HDMI ports i forget haha)
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
As long as it can support a peppy CPU (none of that ATOM junk sry
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yes... I have a Windows 7 key from a family key dedicated to this build
Its pretty much a straight forward build... The only thing is that I want the machine to be pretty peppy to be able to handle HD video (Youtube) and light gaming (Facebook stuff and maybe later steam type games)
The reason I ask is because I did a build before http://hardforum.com/showpost.php?p=1034144012&postcount=26 and that was just a budget all purpose LIGHT gaming rig (currently on ati 4830 card)....
Im thinking I could build similar along the lines of the build i got suggestions on...
main concerns:
-- they want a small form factor case because it is going to be hooked up to the tv (so wireless keyboard and mouse is a must as well as probably a Mini ITX or cube type shape so it wont be too overwhelming to sit next to the tv haha) i know space will be an issue so im not fixed on setting my limits to just a MINI ITx case haha
-- graphics card wise do i need it or would onboard graphics be sufficient? im worried that if i go that route anything intensive like even Youtube HD vids or HULU would be too intensive on the CPU
-- wireless N adapter would be a must also since all comps on our network are running N
-- of course this may become a primary machine to upload video and photos from their digital cameras and things of that nature (again i dnt knoe if this is gonna be a matter of $ on spending on the CPU and possibly GPU haha)
Here's some components i was looking :
http://www.newegg.com/Product/Product.aspx?Item=N82E16811190110
case wise something like this at around 40 bucks would be pretty ideal for the setup i want my parents to have....
thanks guys!
CA
EVERYTHING
NONE
No
ASAP
main concerns:
thanks guys!
