pc-60 extra fan mod
oOo sam lee oOo
a few days ago, it might have been here or on some other site, someone wrote a guide on how to add an extra fan to the back of a lianli pc-60. if i was gonna get a pc-65, would it work too?
The PC-65 is just a PC-60 with a window panel so it'd work exactly the same on either case so long as it doesnt involve the side panel at all.
Be fore-warned, however, that there is no room for error, and that you'll be stuck with an ass-ugly hole in the back if you fuck up... like I did. Only way two fans will fit on mine is if I dremmel one side of them up!
