Past 640X480?
altec
Well i just plugged my computer into my HD tv and i can't get it to go past 640X480. When i try to go higher the video looks all Fup. Is it my TV or something to do with settings?
Edit,
Sorry if i'm not explanning very well. Its all i got.
You said an HDTV? yes? well that should go up to your native res and look excelent, unless its one of those suposed CRT HDTVs, those should hadle a few more resolutions that just the native. btw, old CRTs that are not HD, look best at 640x480, thats the stadired res for most non HD TV, so i really have no idea what the problem is, maybe you could explain a little bit more, and maybe some pics/screenshots.
Edit,
How did you plug it in? Component? Composite? S-Video? Composite and S-Video can only give you 640x480 since they are non-HD inputs. Component would be what you'd need for this.
Cant DVI do it as well?
