I have an unRAID box that I recently put together, and I'm trying to get the noise levels down.
The system specs are:
Athlon II x4 605e @ 800MHz, 0.875V
785g chipset
4GB DDR3
4x HDDs (2x7200rpm, 2x5400rpm)
The stock CPU HSF is really loud; it's quite old and makes a high pitched whine.
I replaced the rear exhaust fan on the case with a 120mm Gentle Typhoon, and I just ordered a Cooler Master TX3 to replace the stock cooler.
Can I run the TX3 passively with the CPU underclocked/volted as I have it?
785g chipset
4GB DDR3
